Axle Lock Nut Tool - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-19-2014, 07:22 AM Thread Starter
Axle Lock Nut Tool
Specs: 1997 F250HD XLT 4x4 7.3L Powerstroke 8800lbs GVW manual hubs
I need to replace my inner & outer bearings. First I need the special tool to get the lock nut off. My manual says it is D85T-1197-A. Neither my local O'Riellys or NAPA stores had the tool.
Is this it??
OTC , 7158 Ford FW Bearing Locknut Socket D85T-1197-A
Also, any other special tools I need?
Help!
Thanks in advance
Mike
97' F250HD XLT 4x4 | NAPA 6637 | TS Chip | Straight Pipe | CCV Mod | LED lighting | Coolant Filter | 203 Thermostat|
mikeallenbrown is offline
post #2 of 7 Old 07-19-2014, 07:26 AM Thread Starter
Also, I need to replace the Hub Body bearings but my manual doesn't depict them. I out up a pic if needed. Anyone know where to source these bearings?
Mike
post #3 of 7 Old 07-20-2014, 06:14 AM Thread Starter
Went ahead and bought the tool ...sure hope it's the right one...
Mike
post #4 of 7 Old 07-20-2014, 06:55 AM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
We carry them at NAPA. I got one for my truck. It most likely has the just the ears on the end and not the enclosed type.
dirtcrew51m is offline
post #5 of 7 Old 07-20-2014, 07:23 AM Thread Starter
Could you provide me the part number and/or URL to that??
My local NAPA says they don't carry them in the store and that it's a special order.
Mike
post #6 of 7 Old 07-20-2014, 06:29 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Not sure if this helps, but I use a NAPA 3246 on my 97 F250 with manual hubs. Cheers!
Patrick Feeley is online now
The Following User Says Thank You to Patrick Feeley For This Useful Post:
mikeallenbrown (07-28-2014)
post #7 of 7 Old 07-28-2014, 02:32 PM Thread Starter
The tool I ordered ( OTC 7158 FW Bearing Locknut Socket D85T-1197-A ) worked great.
Mike
