Starting issue and oil pressure gauge - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-16-2014, 08:33 PM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
I have a 1994 f350 Powerstroke. I bought it knowing it wasn't ran in awhile he told me he started it last fall or something I had it running before I took it apart to fix everything. I just drained all the old diesel witch smelled like turpentine I thought it was really odd for the diesel to smell like that and look like gas but when I syphoned it I got a mouth full and it was defiantly diesel I also replaced the fuel filter. My glow plug solenoid relay broke. I got the truck started without it but after I get it warm and shut the motor off and try to start it I crank and it turns over for awhile then starts. I also noticed that the oil pressure gauge on my dashboard is not working but the engine runs fine and sounds good I need some help or input.
Edit: Also where is the oil pressure sensor located I hope its only a bad sensor.
bdemutis is offline
post #2 of 4 Old 07-16-2014, 10:04 PM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
Also when I did my oil change today I filled my filter to the top and put it on but I was 2-3 quarts low at first because I forgot to buy another gallon and I cranked it over to check the level could I just have air trapped in the system I think I put in about 14.5 quarts but at first I only had probably 12 quarts of oil in it.
bdemutis is offline
post #3 of 4 Old 07-28-2014, 07:30 PM
From my limited understanding of the pressure gauge its either on or off. When the truck is running it reads at a set point on my truck and does not move until I turn the truck off and then it falls to zero. Maybe an add on gauge or a tuner could give you a better indication of actual pressure. 7.3 holds 15 quarts, except the vans which are 14. Not sure if any of this helps you or not....
A cheap method to tell if you have diesel in your oil is to drop a single drop of oil on a sheet of white paper. If there is fuel present it will wick into the paper quicker than oil. It will be sorta like a translucent ring around the drop of oil. This is by no means a scientific test but a quick rough check.
I am not sure what the minimum oil level required to run is. I ran my truck for a year one quart over full until I learned vans are 14 quarts. No ill effects.
INISLDR is offline
post #4 of 4 Old 07-28-2014, 08:48 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
The original 94.5's (like mine) had a 12-quart dipstick, which they later had a TSB on to change the dipstick for what I will call the 14-quart stick. My 94 ran basically fine on 12 quarts. Since then I've always used 14 quarts for an oil/filter change (capacity would be more if you could get out all the HP oil system oil). Oil pressure "switch" (that's all it is ... it is not a true sensor) is on the top of the HPOP Reservoir. Cheers!
Patrick Feeley is offline
