AC compressor no power. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-13-2014, 07:34 PM Thread Starter
WelchyBoy833's Avatar
As the title states I have no power to my ac compressor. I have checked the low pressure sensor about the evaporator and the high pressure sensor on the back of the compressor and have no power at either one. My number 6 fuse in the cab is good and not blown. Could any one help me with a wiring diagram of this electrical system? Or some knowledge about what else to check? My next guess is that the switch in the cab is bad or else its a dreaded short in the wiring somewhere...
Thanks for any and all help!
'97 ZF5 4x4 340,000 K&N full intake 3''dp to a full 4'' straight pipe Superchips tuner
WelchyBoy833 is offline
post #2 of 10 Old 07-13-2014, 08:52 PM
sgt dave's Avatar
Quoted: 3 Post(s)
Check the plug that's at the front of the compressor. I just went thru the same issue and found that plug was broken. I spliced in a new plug and all is good.
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
post #3 of 10 Old 07-13-2014, 08:57 PM Thread Starter
My plug is fine, but now I think about it, in the harness between the alternator and ac compressor I found a piece of heat shrink with a diode soldered into the black wire and, tied into a few other wires, did you happen to see anything like that on yours? The way it looks it looks like it was done factory, but that's always something to check on when you see wires scabbed together like that.
post #4 of 10 Old 07-13-2014, 08:59 PM
sgt dave's Avatar
Quoted: 3 Post(s)
No, I didn't see anything like that. I split the loom back about 6-8"
And checked all of the wires.
USMC 1993-1998
sgt dave is offline
post #5 of 10 Old 07-13-2014, 09:01 PM Thread Starter
hmm could be some of my issue I guess, but I don't have any power to the low pressure switch and everything I have read says that is the first part of the circuit, so somewhere between the HVAC controls and the low pressure switch I have an issue I guess
post #6 of 10 Old 07-13-2014, 09:28 PM
sgt dave's Avatar
Quoted: 3 Post(s)
Possibly, but that plug on the front of the compressor was causing mine not to work. Good luck!
USMC 1993-1998
sgt dave is offline
post #7 of 10 Old 07-14-2014, 05:31 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Diode might be blown. Check the voltage before and after the diode. I think I have a schematic for the ac circuit, let me know if you need it.
dirtcrew51m is offline
post #8 of 10 Old 07-18-2014, 08:19 PM Thread Starter
if you could upload the schematic I would be very grateful! I cant check voltage, because I am not getting any voltage anywhere in the system, and the fuse isn't blown.
post #9 of 10 Old 07-19-2014, 08:11 AM
Patrick Feeley's Avatar
Quoted: 9 Post(s)
Here's the schematic from the 1997 EVTM. Cheers!
Patrick Feeley is offline
post #10 of 10 Old 07-20-2014, 08:10 PM Thread Starter
thanks for the schematic! I figured it out, had a wire making a bad connection on the back of the HVAC controls. I now have AC! Thanks everyone!
