Help with license plate light - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-07-2014, 03:50 PM Thread Starter
pk64f100's Avatar
I am trying to pass inspection in state of md and found out the lic plate light is missing due to custom bumper. I think it is brown hot and black ground next to drivers side tail-light. Is this correct anyone, if not any easy way to wire up a universal light from advance auto? thanks i
2. I think brown wire with flat connector is hot for lic plate light?
3. Think blk wire is grnd?
Thanks.
ID:	309137   Click image for larger version
pk64f100 is offline
post #2 of 2 Old 07-07-2014, 07:54 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Those colors are correct for power and ground. Those wires should tie into the same color wires for the Rear Park/Stop/Turn Lamps. Cheers!
Patrick Feeley is offline
