Lighting Problem with LED Taillights - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-04-2014, 11:28 AM Thread Starter
Just made some LED tailights and ran into some lighting problems:
When I have no lights on (running lights or headlights), when ever I touch the brake, all of the lights flash when I hit the brakes.
No reverse lights
When I turn the right blinker on, it just stays lit like its going to flash but doesn't.
The left blinker works fine all of the time.
These lights work great and I wouldn't want to throw it all away just because of a simple fix. If anyone could chime in with suggestions that'd be great! thanks!
'97 4x4, 6637 Riffraff intake, 4" Straight pipe
smill24v is offline
post #2 of 4 Old 07-04-2014, 04:50 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Get an electronic flasher. They have the load to drive the led lights.
dirtcrew51m is offline
post #3 of 4 Old 07-05-2014, 04:23 AM
This is the flasher I use:
CF12ANL-01 LED Bulb Electronic Flasher | Flashers & Load Resistors | Car Bulb Installation Supplies | LED Car Bulbs | Super Bright LEDs | Super Bright LEDs
I have LED all around. This works great.
I should add, however, the only problem I encountered when I switched to LEDs was I had no turn signals. Everything else worked. The symptoms you describe I didn't experience.
Mike
97' F250HD XLT 4x4 | NAPA 6637 | TS Chip | Straight Pipe | CCV Mod | LED lighting | Coolant Filter | 203 Thermostat|
mikeallenbrown is offline
post #4 of 4 Old 07-07-2014, 05:48 PM Thread Starter
Thanks man, ended up getting that flasher and the thing causing all the problems was a crossed wire haha thanks for the heads up on that flasher though!
smill24v is offline
