funny idle at start?? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 01-19-2009, 05:07 PM Thread Starter
I have a 95 7.3 turbo stroke. It runs like a top, and pulls hard, but I am having a wierd problem at startups. It fires right up but it does this wierd lope or chug for about three to four seconds and then smooths right out to normal. It doesnt matter if its the first start of the day or if it is totally warmed up. sometimes it does it worse than other times. Sometimes it doesnt do it at all. I have a buddy with the same truck and it starts smooth. I was hoping you guys could help me out on this one. Like I said the truck runs fine its just annoying. Thanks in advance for your help.
95 OBS crew cab long bed 4x4- hombrew intake-
88flexj is offline
post #2 of 15 Old 01-19-2009, 05:08 PM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
Mine did that when I had the breather off to replace o-rings. Check bolts
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #3 of 15 Old 01-19-2009, 05:11 PM Thread Starter
Can you elaborate on that. What breather and bolts? Thanks for your help.
88flexj is offline
post #4 of 15 Old 01-20-2009, 02:37 PM Thread Starter
Anyone? People look at me funny when I start it up sometimes.
88flexj is offline
post #5 of 15 Old 01-20-2009, 02:43 PM
scuffs *****
Tyler's Avatar
The breather is the little box on the drivers side valve cover. Check that bolts to it are tight. Ive had it happen when running out of fuel as well. Other than that idk.
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
post #6 of 15 Old 01-20-2009, 04:42 PM Thread Starter
Ok, Ill check that. Thanks.
88flexj is offline
post #7 of 15 Old 01-20-2009, 04:46 PM
99psd's Avatar
mines a 99 and does that sumtimes,so would like to know the reason.
2001 F-250 psd
Isspro gauges(pyro,boost,trans.)
Dp tuner(stock,80econo,120race,140smoke,lope smoke)
4in downpipe-5in exhaust-7in tip
boost fooler
resistor mod
305-70-16 kuhmo mt's
16in eagle alloys
soon to come:
IDM MOD.
ITP return system
leveling kit
99psd is offline
post #8 of 15 Old 01-20-2009, 05:11 PM
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
Is it like this?
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #9 of 15 Old 01-20-2009, 05:44 PM Thread Starter
Originally Posted by cob32187 View Post
Is it like this?
No its a lot less obvious than that but similar. It smooths out in a couple seconds. Im afraid that if I dont do something about the problem it will be that bad eventually.
88flexj is offline
post #10 of 15 Old 01-20-2009, 05:58 PM
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
Mine smooths out when i give it a bit of throttle. It was about 25* when i did that though.
BPS President
Jake is offline
