gauge install problem - Ford Powerstroke Diesel Forum
Old 01-18-2009, 12:59 PM
well i bought these gauges used and they ofcorse didnt come with any instructions so i am lost
im starting to wonder if the guy sent me everything that i need to hook them up
here is a couple pics of what i got
is this everything that is needed? how dose everything piece together?
here is a link that raul sent me that is helping pretty well but im not real good with all the technicle names for all the parts and wat not
http://stealth-automotive.com/docume...%20Install.pdf
Old 01-18-2009, 01:05 PM
yep looks like everything,for the boost line ,in your first pic,were you have the 3 parts in a row,thats how they go,feed the boost line through the first one,then work the smal piece on to it,then screw it on to the piece that threads onto the gauge,pyro is pretty straight forward i think,drill and tap exh. manifold,drivers side,feed the wire up to the gauge and hook it all up,should be pretty easy.goodluck
Send a message via MSN to pinkfloyd
looks like you have everything. as far as instructions go here's a link that might help Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
Old 01-18-2009, 01:06 PM
i have a manual trans so ive never hooked up a tranny line before.
Old 01-19-2009, 02:08 PM
now how do you keep the boost line in there?
when you screw everything on it just pulls right back out?
Old 01-19-2009, 03:01 PM
ok i see what you do-the little round thing kinda pinches the hose if you tighten it on down!
ok so i have the boost gauge under control and the pyro to
last question-on the pyro gauge there is a hot and ground wire comeing out of it, where do those wire into
and the lights for both gauges have ben wired into one common positive and ground but one wire is black and i is white, i know that you wire it into the dimmer switch but witch ones?
Old 01-19-2009, 05:36 PM
Send a message via AIM to BennyLumpkin
you can run the hot wire for each of them together if dont mind ur lights being on in ur guages all the time....otherwise run ur regular hot to an ignition hot and the others to a power switched by your headlights
Old 01-19-2009, 05:39 PM
how do i go about wireing this into my ignition?
Old 01-19-2009, 05:41 PM
Sparkplugs Not Required
do you have the amplifier boxes for the pyro and trans temp gauges?
Old 01-19-2009, 05:48 PM
i olny have the boost and pyro but i gess since im lost on an amplifirer box i must not have one lol
