Obs 7.3 no start/ missfiring - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-29-2014, 12:40 PM Thread Starter
So it passes buzz test, but it cranks and trys to start but missfires until dies when it starts. Only codes I got are glow plugs but I have it plugged in so that should stop that. Maybe my injectors are dead? It gets up to like 2.9k injecting pressure and % is 15-45%. Hpop?
Matticus is offline
post #2 of 3 Old 06-29-2014, 08:18 PM
Quoted: 2 Post(s)
Optional Step 0: Do you see any RPM indication on the tach when cranking? You should. If not...
Step 1: Replace your CPS.
Step 2: Determine if the issue still exists.
If issue still exists with a new CPS, continue troubleshooting. They fail regularly, and fail in a manner that causes these symptoms.
Syonyk is offline
post #3 of 3 Old 06-30-2014, 06:22 AM Thread Starter
Already changed it. Tach moves. I'm thinking bad injectors or IDM. It fires, I got fuel smoke pouring out of exhaust. It just missfires and dies. IDM?
Matticus is offline
