Help!!! No start,No rpms!!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-27-2014, 11:04 AM Thread Starter
Farley95Stroke's Avatar
Hey i got a 95 Powerstroke, 247xxx miles, and i need some help. I was going to work the other day and before i left i went to crank the truck and the check engine light came on. Turned off the key and it started right up. When coming home from work it did it to me three times before it started. Next day it wouldn't start at all. Ran fine once started just wont start. No rpms or smoke either. I figured it might be the CPS, but if it was then wouldn't it just go out or be accompanied with hiccups ans stalls???? I will be changing out soon, but need to be prepared for other options. Does this sound like a CPS? Thanks
Farley95Stroke is offline
post #2 of 5 Old 06-27-2014, 12:26 PM
Quoted: 43 Post(s)
Sounds like you need to obtain the codes associated with the CE light. But yes, CPS is a prime suspect.
madpogue is offline
post #3 of 5 Old 06-27-2014, 02:31 PM Thread Starter
Ill have access to a good code reader next week, hopefully the cps does it
post #4 of 5 Old 06-28-2014, 06:54 PM
Quoted: 2 Post(s)
If you're not seeing RPM on the tach while cranking, that's a very strong indication that the CPS is at fault.
Syonyk is offline
post #5 of 5 Old 06-30-2014, 12:07 AM Thread Starter
It was the cps. Thanks guys
