New tie rod problem - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-20-2014, 01:20 PM Thread Starter
New tie rod problem
Installed new tie rods today. I messed up and pumped too much grease into one of the boots. This created a pin hole where the grease leaked out.
Is this fixable? ...do I need to replace the tie rod again? ... maybe it'll be ok?
Thanks...
Mike
97' F250HD XLT 4x4 | NAPA 6637 | TS Chip | Straight Pipe | CCV Mod | LED lighting | Coolant Filter | 203 Thermostat|
mikeallenbrown is offline
post #2 of 8 Old 06-20-2014, 01:56 PM
Quoted: 53 Post(s)
Pin hole in the boot? Just replace the boot. You can buy 'em by the dozen, Energy Suspension makes them. Might find singles at the FLAPS.
madpogue is offline
The Following User Says Thank You to madpogue For This Useful Post:
mikeallenbrown (06-20-2014)
post #3 of 8 Old 06-20-2014, 01:58 PM Thread Starter
Oh ok ...just that simple? It's my first time doing tie rods and I wasn't sure.
Thanks!
Mike
post #4 of 8 Old 06-20-2014, 06:50 PM
Quoted: 53 Post(s)
Oh you're the dude who posted last week; did you end up getting the NAPA parts? Retail, at the store? Shoot, I'd just go in with the boot and explain what happened, maybe they'll consider it a defect and swap it for you. Seems like a new boot shouldn't do that even with overdoing it on the grease gun, unless you really gorilla-muscled the lever, or used a power grease gun.
madpogue is offline
post #5 of 8 Old 06-21-2014, 04:41 AM Thread Starter
Yeah, got NAPA parts (online). The boot is on the draglink ball that connects to the pitman arm. Don't really want to take it all apart for a boot. I'll just replace it. No worries.
I wasn't sure how much grease to put it so I kept pumping until I saw the boot start to bulb a little. Then I torqued down the castle nuts. I maybe I should have torqued down the nuts first THEN pump the grease.
Mike
post #6 of 8 Old 06-21-2014, 07:22 AM
Quoted: 53 Post(s)
Yes, assemble, tighten, THEN grease. And you don't have to take anything apart to replace the boot. You pop the joint off with a joint tool and just pry the boot off.
madpogue is offline
mikeallenbrown (06-21-2014)
post #7 of 8 Old 06-21-2014, 07:32 AM Thread Starter
Perfect ...thanks!
Mike
post #8 of 8 Old 06-21-2014, 07:34 AM
ZMANN's Avatar
Quoted: 1662 Post(s)
technically it's just a dust seal
it wasn't designed to hold grease it just does that be default
if the pin hole is small I wouldn't worry unless it can let water and dirt in
We Miss you Ronnie
ZMANN is online now
