Front Brake Rotor advice - 97' F250 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-14-2014, 07:41 PM Thread Starter
97' F250HD 4x4
I need to replace my front brake rotors. They are in terrible shape. I've been watching a couple of youtube videos of other people doing this. One question that came to mind was: Do I need a spindle socket?? ...if so, what size? I have a service manual but it doesn't mention this (unless I missed it). Also, any other advice you think I could use?
Thanks in advance!
Mike
97' F250HD XLT 4x4 | NAPA 6637 | TS Chip | Straight Pipe | CCV Mod | LED lighting | Coolant Filter | 203 Thermostat|
mikeallenbrown is offline
post #2 of 4 Old 06-14-2014, 09:27 PM
Patrick Feeley's Avatar
Quoted: 9 Post(s)
Manual or Auto Hubs? I used a NAPA 3246 on my 97 F250 with manual hubs. I also used a 20-ton shop press to press out the wheel studs and to press them back in (the big hammer method usually turns out bad for me when I try it!). Get new bearing grease seals and repack the bearings while you are there. Cheers!
Patrick Feeley is offline
The Following User Says Thank You to Patrick Feeley For This Useful Post:
mikeallenbrown (06-15-2014)
post #3 of 4 Old 06-15-2014, 05:35 AM Thread Starter
Manual hubs.
Mike
post #4 of 4 Old 06-15-2014, 07:29 AM
Quoted: 9 Post(s)
You will need the special socket. Make sure that wherever you get one that you tell them you have the Dana 50 front axle. For the torque specs/sequence: Tighten the inner nut to 50 ft-lbs, then back off 90 degrees. Tighten the outer nut to 160-205 ft-lbs. Check the torque required to rotate the hub/rotor. Torque required to rotate the front disc brake hub and rotor is not to exceed 20 INCH-lb. Cheers!
