Best sources for Electrical parts? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-14-2014, 05:16 PM Thread Starter
seven3stroker's Avatar
Hey all,
So as I continue with my trucks issues and it's not wanting to run, bout to go on a replacing spree. It does the WTS light hiccup where you have to let off and reset the gas pedal. It's also likes to just shut off with or without the CEL, sometimes it will start right back up and sometimes it won't. Will do it under any condition, but the biggest thing is having my aftermarket stereo turned up or when you just let off the fuel; like cresting a hill or when pushing the clutch in. Problem has been getting progressively worse.
System is all hard wired except deck, have 4 gauge battery cables running the amp off of both batteries.
Have a new DC power 320amp alternator.
2 new diehard platinum 950 batteries.
New batteries cables.
New solenoid on the passenger side fender.
Tried 3 different CPSs, currently have a dark grey ford one from a 96. The lighter gray one is what the said I needed but I ignored them and I know my build date was Tuesday jan 7 1997.
Some call this issue TSB-97-15a
Last trivia piece is I have a ALF6 PCM which most cheat sheets show as a 96 manual truck.
My truck is a 97 f350 xlt cclb 4x4 manual 49states
I'm just going to do new parts before I get so pissed I torch the damn thing and collect insurance. So any suggestion on where to get these. Thanks for reading this saga and helping!!
IDM... Gonna do a swamps upgrade
PCM..
ICP..
IPR..
Going to reburn my TW 6pos
CPS harness..
Valve cover gaskets and harnesses if they make replacements..
GPR.
EBP sensor..
Anything else anyone would replace and where do I get it from.
Sent from AutoGuide.com App
1997 F-350 PSD CCLB 4x4 215k ZF-5
SGT Roth, US Army
seven3stroker is offline
post #2 of 2 Old 06-14-2014, 05:23 PM Thread Starter
Also I'll do the throttle sensor and the idle sensor?
SGT Roth, US Army
