tie rods & drag link need for a 97' F250 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-12-2014, 12:38 PM Thread Starter
I'm having a hell of a time trying to find correct parts...calling O'Rielly or Autozone was next to useless and Googling around wasn't much better. I can't seem to get a straight answer! ...the JC Whitney site gives me several options but the pics all look the same and they don't tell me what the differences are (except price). I'm wanting heavy duty parts. I live out in the sticks and go 4 wheeling on occasion ...I need some help here:
I need both tie rods and the two drag links (the ball studs on these are either missing and uselessly rotted).
Mike
97' F250HD XLT 4x4 | NAPA 6637 | TS Chip | Straight Pipe | CCV Mod | LED lighting | Coolant Filter | 203 Thermostat|
mikeallenbrown is offline
post #2 of 9 Old 06-12-2014, 02:02 PM
Quoted: 43 Post(s)
Try RockAuto.com. What the AutoZtoners (etc) don't get is that in '97, there was a "light duty" F250, which was based on the new-generation F150 (it should have been called an F200), a completely different chassis. These parts are gonna be the same as for a '96, so wherever you look or ask, lookup by both years to confirm the right numbers. RA lists them all under "Tie Rod End", BTW, and the sleeves are in a separate category.
madpogue is offline
The Following User Says Thank You to madpogue For This Useful Post:
mikeallenbrown (06-12-2014)
post #3 of 9 Old 06-12-2014, 02:24 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Go to NAPA, if you need part numbers I will look them up and post them. We have all the parts to do a complete rebuild. I can tell by the photos of what you need.
dirtcrew51m is offline
The Following User Says Thank You to dirtcrew51m For This Useful Post:
post #4 of 9 Old 06-12-2014, 03:10 PM Thread Starter
Thanks! .... Does this look right to you?
Mike
post #5 of 9 Old 06-12-2014, 05:54 PM
Quoted: 6 Post(s)
Yes they do look right, I will still check at work tomorrow, when I did my steering I reused the adjuster sleeves, they were fine, and if you want the better\heavy duty parts go with the NCP line not the MRC line, the NCP is lifetime warranty, the MRC are 1 yr warranty. I have some heavy duty customers who only use the NCP line because they dont want the trucks coming back. You also have to watch wit the F250's, there is a standard and a heavy duty version of the trucks, I found that out with mine, it is an F250 with F350 stuff like ujoints and the front end parts. Probably done for the 7.3 while the gas motors use the standard 3\4 ton parts.
post #6 of 9 Old 06-12-2014, 06:07 PM
Quoted: 43 Post(s)
Actually, it's the other way around. See above. Our F250s, the ones relevant to this site, are the "standard" duty F250. It's the same F250, with changes over the years of course, that had been around for decades before. The '97 "light duty" F250, based on the new style F150 of that year, is the one that is more appropriately thought of as an "F200". And neither one is the same as an F350; the F350 has a Dana 60 front end with a solid axle and completely different steering components, whereas the F250 has a Dana 50 with a twin traction beam (TTB) axle. And who cares what the "light duty" F250 has.....
I ended up getting new sleeves, for a simple purpose. It allowed me to drop the whole existing assembly, then build up the new one, matching the spacing between the ball joints. Then I hung the whole new assembly all at once. This also gave me the option of re-hanging the old assembly as a "fall-back", in case anything went wrong (IT lesson - always advantageous to have an "undo" strategy).
madpogue is offline
post #7 of 9 Old 06-12-2014, 06:27 PM
Quoted: 6 Post(s)
Forgot some of the 96,97, and 99's are different than the 95 and down, my truck is a 95 F250, yet it has all of the components are of an F350, such as the steering and ujoints, when I looked up the parts for my truck there were 2 versions, my truck has all of the larger components. Sometimes it drives me nuts looking up steering parts for truck shops we sell to, its either or, and hope I send them the right parts.
post #8 of 9 Old 06-12-2014, 06:49 PM
Quoted: 43 Post(s)
Then someone has swapped in a Dana 60.
madpogue is offline
post #9 of 9 Old 06-13-2014, 06:15 AM
Quoted: 6 Post(s)
The NAPA quality parts are,
272-4201 L inner
269-5139 R inner
269-2929 L outer
269-2930 R outer
269-1123 R adj sleeve
269-1134 L adj sleeve
mikeallenbrown (06-13-2014)
