Oil cooler problems - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-10-2014, 06:46 PM Thread Starter
Oil cooler problems
I was changing my oil today and when I removed the oil filter, a spring/washer fell out. this was a new one on me so now I am in the process of putting a new one in. My question is, when I put on the new gasket, do I need to put any kind of sealant on the gasket or just put it on? This will be my first time changing one, it will be a few days before the parts come in so I want to have everything ready.
1995 Powerstroke F-250
Super Cab 4x4
2012 F-250 CC Lariat 6.7 4x4
grish is offline
post #2 of 4 Old 06-10-2014, 08:47 PM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
Are you putting on a new filter/cooler adapter? The gasket that goes on the block does not need sealant. Make sure you have the oil cooler O-rings as well. A "pony" pipe clamp works good to draw the cooler headers onto the cooler itself. Cheers!
Patrick Feeley is offline
post #3 of 4 Old 06-11-2014, 08:45 AM Thread Starter
Yes I am putting on a new filter/adapter and wanted to make sure the gasket to the block didn't need anything. I have the O-rings as well. Thanks for your help, now to get the job done!
Super Cab 4x4
grish is offline
post #4 of 4 Old 06-12-2014, 02:33 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
No sealant should be used. The gaskets go on dry, or only use some high tack to hold the gaskets on while installing the cooler. Using sealant give a chance of when squeezed out could end up going through the system and possibly clog something up.
dirtcrew51m is offline
