heater switch?? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 01-06-2009, 04:37 PM Thread Starter
Full A-Team Member
Fordman247365's Avatar
heater switch??
not sure what the problem is, went to switch heat to blow on floor and will only defrost on any setting.......any ideas
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #2 of 22 Old 01-06-2009, 04:54 PM
as i have heard on here, it sounds like a bad vacuum pump
19558077 is offline
post #3 of 22 Old 01-06-2009, 05:54 PM
h2odrx's Avatar
you need to check for vacuum coming in to the cab.
Remember, we aren't eating this stuff, we're turning it into diesel fuel. Your truck only cares about viscosity, acidity, and BTUs. Nothing else. -unknown?
NC State law defines biodiesel as ''any fuel or mixture of fuels derived in whole or in part from agricultural products or animal fats or wastes from these products or fats.''
h2odrx is offline
post #4 of 22 Old 01-06-2009, 06:11 PM Thread Starter
Full A-Team Member
where is the best place to check for vacuum, and if there is none its the pump?
thx for the quick replies =)
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
post #5 of 22 Old 01-06-2009, 06:50 PM Thread Starter
Full A-Team Member
just wanted to add.....the heater switch is all i have a problem with, my brakes work fine??
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
post #6 of 22 Old 01-07-2009, 04:58 AM
THE VACUUM PUMP DOESNT CONTROL THE BRAKES, BUT A TECH CAN HELP YA TROUBLESHOOT
19558077 is offline
post #7 of 22 Old 01-07-2009, 05:38 AM
see if you have any vac line off under the hood by the fire wall the main one is behind the brake booster no it not the vac pump
7.3 rock thrsnoreplcmentFordisplcment
donald lorbeske is offline
post #8 of 22 Old 01-07-2009, 06:11 AM Thread Starter
Full A-Team Member
will check, thank you
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
post #9 of 22 Old 01-07-2009, 11:33 AM Thread Starter
Full A-Team Member
ok i am going to guess that this is where this is going to turn into a pain in the a** =)
first...i have a major vacuum line that runs across the firewall to the pass side of the truck from the 4 post vacuum bank on driver side inner fender. that line to the pass. side splits into 3 or 4 little lines, 3 (i think 3) stay connected to the outside of the heater box under the hood and one goes into the wiring harness and goes into cab. i pulled off one of the small lines under the hood by the heater box and it has vacuum, i dont know how much, i dont have a gauge, but it was enuff with the very small tube to keep it stuck to my finger, so if i have vacuum.....??? I am pretty sure this is where the pain in the butt starts lol
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
post #10 of 22 Old 01-07-2009, 03:13 PM
do you have vac at that one accuator by the right fender im not sure if that controls the defrost. did you check the switch inside that bezel around that panel just pulls of with a little effort take a screw driver and gentle remove it
