97 7.3 no start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-27-2014, 11:08 AM Thread Starter
1995psd's Avatar
97 7.3 no start
Hey guys I have a 97 international roll back with the t444e (7.3) this thing absolutely will not start. Will run off either but not fuel. I have no access to a computer to hook to this truck but it has roughly 274k miles. New cps icp irp hpop lift pump injector harness and still nothing I've checked all fuses they are all good. Another mechanic did all the parts before but still no start. Seems to be getting fuel changed filter and sock on back side of filter housing and fuel sprays out when you open the Shrader valve. Getting white smoke out of the exhaust also. A cording to the owner it was running when parked this winter but wouldn't start this spring. Any help would be greatly appreciated thanks!
1995psd is offline
post #2 of 4 Old 05-27-2014, 11:12 AM
Quoted: 53 Post(s)
If it's making smoke, it's delivering fuel. Sounds like glow plugs - relay, wiring, UVCHs, GPs themselves. The fact that you didn't blow anything up with the starting fluid suggests that the GPs aren't working.
madpogue is offline
post #3 of 4 Old 05-27-2014, 11:20 AM Thread Starter
1995psd's Avatar
Even if the glow plugs weren't working should still start and run from either. Will fire right up off it and run till it burns it all out
1995psd is offline
post #4 of 4 Old 05-28-2014, 01:25 PM
quicknick106z's Avatar
No compression, If it runs off eather but not diesel its not got enough compression, eather makes compression..
96 ford f250 7.3 edge evo straight pipe (Blown up Junk
quicknick106z is offline
