ICP o-rings keep breaking - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-21-2014, 05:00 PM Thread Starter
Farley95Stroke's Avatar
hey, i got a 1995 powerstroke. ICP went bad so i bought a new one. Aftermarket not oem, installed at spec torque. First o-ring broke in three days. Bought some more and have been through about 5. last for about a day a piece and cause a massive oil leak when they bust. Need to know i this is common or if i need a performance o-ring. put old sensor back in and no leak. Thanks.
Farley95Stroke is offline
post #2 of 3 Old 05-21-2014, 06:44 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
You need a Viton O-ring [(Ford) F4TZ-9N693-A, (International) 1815874C1 (o-ring for HPOP hose to head joint, port plugs and ICP)]. Also, lightly oil it when installing it. Make sure there are no burrs or other issues on the o-ring sealing surface of the new ICP. Cheers!
Patrick Feeley is offline
post #3 of 3 Old 05-22-2014, 07:43 AM Thread Starter
Thanks. I ordered some of those rings. Any other input from anyone?
