7.3 dead. - Ford Powerstroke Diesel Forum
post #1 of 29 Old 05-19-2014, 07:18 AM Thread Starter
quicknick106z's Avatar
7.3 dead.
231k and im cruising 45 and it went pufff and will not re start, throwing code ICP voltage
quicknick106z is offline
post #2 of 29 Old 05-19-2014, 07:53 AM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
Check for oil in icp plug and check for chaffed wires on pig tail. Also check your ipr wires for chaffing.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 29 Old 05-19-2014, 08:53 AM Thread Starter
oil was in icp cleaned it out still wont fire
post #4 of 29 Old 05-19-2014, 09:02 AM
Quoted: 54 Post(s)
If there was oil in the ICP connector, the sensor has most likely failed. Its seal has been compromised. Cleaning the oil out won't help. It's not (necessarily) the oil that throws the code. The seal failure means that it's no longer reading the pressure properly.
Try starting it with the sensor disconnected. That should set a "default" value that will at least allow the engine to start (it wont go down the road well).
madpogue is offline
post #5 of 29 Old 05-19-2014, 01:56 PM Thread Starter
unpluged it i think? top of the intake drivers side?, still wouldnt start back up
post #6 of 29 Old 05-19-2014, 02:29 PM
Quoted: 54 Post(s)
What do you mean by "intake"? The ICP is on the driver's side cylinder head, inboard side, toward the front.
madpogue is offline
post #7 of 29 Old 05-19-2014, 03:10 PM Thread Starter
^ yes i unpluged it nothing?
96 ford f250 7.3 edge evo straight pipe (Blown up Junk
post #8 of 29 Old 05-20-2014, 05:18 AM Thread Starter
took both batterys out of the truck, no check engine light no more icp code, now it says cam position sencer, also doesnt fire up doesnt even smoke, has oil pressure but idk, soon as its fixed it will be sold its broke down every week.......
post #9 of 29 Old 05-20-2014, 12:40 PM Thread Starter
Im getting cps out of range
post #10 of 29 Old 05-20-2014, 12:50 PM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
I would get two cps's from ford or international ( if you have one around you) install one and toss the other in the glove box.
01 f-250, Standard
sbluke55 is offline
