USING OIL!!! - Ford Powerstroke Diesel Forum
Old 12-28-2008, 01:52 PM
Angry USING OIL!!!
Got a 95 f350 econoline van. with the 7.3l powerstroke. 140k miles. It uses oil.......i mean A LOT of oil. It used 2 quarts in a 100 miles. It only blows blue smoke when its cold......until it reaches normal operating tempt. but after that its fine. never blows any blue smoke when you get on it or anything. I was told that the turbo could be using the oil???? How do i find my problem???? any help would be great! Thanks
Old 12-28-2008, 03:36 PM
Send a message via AIM to Maverick1701
how is the air filter? If it is clogged it will suck oil outta the CCV....I had a similar situation on my old white obs and couldnt figure out where my oil was going lol
Old 12-28-2008, 03:51 PM
check the shafts of the turbo
how many miles on the psd?
is there oil in the valley, or oil going down the engine
and check the air filter
Old 12-28-2008, 06:43 PM
Fire the truck up, take the oil filler cap off the valve cover. How much blow is there.
Old 12-28-2008, 09:49 PM
Complete service. Including new intake. and CCV mod.
Old 12-28-2008, 09:50 PM
140kmiles. least thats what it says. Runs really good. I put a custom intake on it, and felt the shaft on the turbo......couldnt fell any play.
Old 12-28-2008, 09:52 PM
Air filter is fresh. within in the last 500 miles. i will have to check for oil in the valley. but i think its pretty clean. doesnt leave any spots underneath it when its park.
Old 12-28-2008, 09:53 PM
I have the ccv mod done. I will pull the filter off tomorrow if i have time. What will this tell me.....
Old 12-28-2008, 09:54 PM
Nuckin' Futz
i was going through that as well...i went through 7 GALLONS of oil in a month. Turned out the injectors were leaking internally. No blue smoke thing ran like a champ. Haven't had any oil consumption problems since i got it checked out and replaced two injectors.
