Annoying check engine light. HELP!!! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-06-2014, 11:45 AM Thread Starter
Farley95Stroke's Avatar
Hey guys. I have a 1995 f250, with 246xxx miles that i believe has a sensor that's going bad. almost every time when i start the check engine light comes on. It goes off within a minute or so of the truck running, but when it goes off the trucks RPMs surge and either it stays running or dies. I cant imagine that this is good for my truck. I figured it is a sensor. The only code that i'm throwing is P1280. Could this be the ICP?? If i left out something vital please ask me. Thanks in advance.
-Josh
Farley95Stroke is offline
post #2 of 4 Old 05-06-2014, 11:59 AM
sbluke55's Avatar
Quoted: 553 Post(s)
Garage
Unplug your icp and see if there is oil in the plug. If there is, replace the pig tail and icp.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #3 of 4 Old 05-06-2014, 03:45 PM Thread Starter
It is leaking oil fairly bad. Has anyone else ever heard of this sensor being bad with my symptoms before?Im gonna change any way, just curious.
post #4 of 4 Old 05-06-2014, 04:17 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Yes, your symptoms are common with a bad ICP. Cheers!
Patrick Feeley is offline
