Water in fuel? NEED HELP! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-05-2014, 08:39 AM Thread Starter
hey guys I was running my truck one day and then it just shut off and will not start back up. I believe it is because there is water in the fuel. What should I do to fix this problem? thanks:
jonbennett7 is offline
post #2 of 3 Old 05-10-2014, 09:56 AM
Drain the fuel filter, if it reoccurs you may have to use an additive to absorb the water or draain the tanks. If the filter doesn't drain the drain passage may be plugged.remove the filter and suck the fuel out . the sensor is in the bottom of the filter. This is from an experienced newbie.
ufdaland is offline
post #3 of 3 Old 05-13-2014, 06:15 PM Thread Starter
Did all that don't think I have fuel getting to the injectors or the injectors got shot is that a thing?
Tags
fuel problems , need help , obs , wont start
