bouncing speedo - Ford Powerstroke Diesel Forum
Old 12-20-2008, 07:02 AM
bouncing speedo
Hey guys i'm new to this forum but have a problem with my speedo. I have a 95 f350 cc lb with minor mods. The speedo bounces all the time. I have changed out the sensor on the rear end and no dice. I just replaced the wiring harness to the fuel bowl heater because of corrosion. That caused the truck not to run but i dont think it affects the speedo. Any ideas?
Old 12-20-2008, 08:53 AM
pull the diff cover you may have some shavings or crap stuck on the tone ring...
Old 12-22-2008, 05:34 PM
bouncing speedo
mine was bouncing to change senser didnt work. rebuild rearend and the speed senser ring was damaged. replaced it for 60 bucks works great now.
