No start no crank - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-04-2014, 05:26 AM Thread Starter
No start no crank
Truck started acting funny yesterday after i accidentally left my key in the run position for about 8-10 mins . Put the dog in the truck and went to to turn it over and she jumps out of the truck and goes to the neighbors. Anyways went to go catch her and forgot the truck was in the run position. Came back and the truck was dead so i jumped it and it ran fine. Later in the day i was sitting at the store parking lot with the truck running and the rpm gauge started jumping from 700 to 0 and eventually just stopped working. Then my odometer went out along with the speedo. Truck was still running so i drove it a little and the trans was in limp mode so i made it to another parking lot and pulled it in. Shut it off and when i turn the key back on the odometer flashed on for a second before going dead. Truck wouldnt crank just loud fast clicks when trying.Upon inspection i noticed the ground that bolts into the back of the alternator had completely melted off. Figured this was my problem so i replaced the alternator and it still wont start. Replaced the Cps also no change. Has a new speed sensor too. Any Ideas?
97_Stroked is offline
post #2 of 5 Old 05-04-2014, 06:59 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Is the check engine light illuminated? Is the Wait-to-Start light coming on and going off like it normally would? Check all the battery cable connections for corrosion, etc. (both battery ends and the other end of the cables). Have each battery tested (independently). If one is bad, replace both. Cheers!
Patrick Feeley is offline
post #3 of 5 Old 05-06-2014, 05:08 AM Thread Starter
No check engine light. And yes the wts light does come on for a very short period of time, until the relay clicks over then my everything goes dead. I turn the key and as soon as the wait to start light goes away and i hear the click the odo goes out the speedo drops down to 0 and when i try to crank i get very loud fast clicks. batterys tested okay. Replaced the cps and alternator, checked fuses and grounds as best i could. Im stumped
post #4 of 5 Old 05-06-2014, 07:16 AM
Check the grounds again, dont just look at them, pull them off, wire brush them, wire brush the bolts that hold them on and the metal the ground contacts. a while back mine would hard start, idle rough and sometimes cut out. replaced the grounds that attach to the battery, cleaned all the grounds i could find with a wire brush and sprayed them with corrosion inhibitor ($5 at autozone) and havent had a problem since.
had a similar issue on my 1988 mustang 5.0, did the same thing, no issues.
dieselup89 is offline
post #5 of 5 Old 05-06-2014, 07:19 AM
Quoted: 50 Post(s)
Did you LOAD test the batteries, with them disconnected from one another? Put a SLOW charge into each battery, separately, then LOAD test them, separately. The GPs do run for up to two minutes, but that should not run your batteries down to where they won't start the truck. The only thing energized after that is the PCM, and it won't run down your batteries after 10 minutes; certainly shouldn't run them dead.
If the batteries take a charge (or you replace them [see Patrick's note; always replace in pairs]), and you get it started, wait 'til the glow plugs cycle off, then check the running voltage. It could be that your alternator went, allowing your batteries to discharge. It could even be something as simple as the trigger connector for the alternator.
madpogue is online now
