Ticking on acceleration - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-14-2008, 09:47 AM Thread Starter
Hey there, long time reader 1st time poster, but heres the deal, ive always had a Ticking on acceleration and its usually only when i hammer down, it sounds like an exhaust leak, but when i put it in park and rev it, i dont hear the ticking, so if anyone has any info id very much appreciate it. thanks in advance!
stmrebel is offline
post #2 of 5 Old 12-14-2008, 09:53 AM
troid123's Avatar
Send a message via AIM to troid123
fill out your signature so everyone will know what kind of truck you have.
2006 F250 CC Short Bed King Ranch 4x4 (109,000 miles)
4" Turbo Back w/ 6" Tip
SCT x3 w/ Custom Tunes From DJ's/Innovative
03 turbo
Eclipse Navigation/DVD/CD/MP3 w/ Rear Camera
Rear DVD/MP3/CD Entertainment System
Escort Passport SR7 Built In Radar Detection System
K & N Cold Air Intake w/ S&B Replacement Filter
Roll-N-Lock Retractable Bed Cover
Nitto Trail Grappler LT295/70R18
***SOLD 10/31/11***
New Truck:
2011 Ford F-150 Limited 6.2L Super Crew
troid123 is offline
post #3 of 5 Old 12-14-2008, 09:59 AM
97 golden stroker's Avatar
sounds like an exhaust leak to me. you dont hear it when in N because you dont have that mutch back pressure. but when you get on it you start to build boost and then you start to build more back pressure. you should look under the hood to see if you can see black build up at any connections.
97
afe intake
ats intercooler
3in. down pipe to 4in str8
fpr shim
terminator hpop
warm up valve delete
tw 6 position
southbend clutch
Stage ones from Rosewood diesel
SD IDM
d66
12000k hid dual element
thinking real hard about a nozzle upgrade
220k
97 golden stroker is offline
post #4 of 5 Old 12-14-2008, 12:58 PM
Shade tree mechanic
95dieselsmoke's Avatar
I agree, I had the exact ticking you are talking about. didnt hear it neutral. only under load. took it to the local diesel shop and sure enough it was the pass. side exhaust manifold leaking. only took them a few minutes to pinpoint the leak and give me an answer on where it was
MATT
Now featuring a 6.4 fat bottum 6 speed
95 f250--238k and counting
RDS stage I's-TW live tuned-Dana 60 swap-9" lift/40x13.5x20 ProComps-ZF5 swap/short throw/South Bend CON OFE-Iron Bull front-AFE CAI-SD innercooler-Fab Tech traction bars-MBRP DP/6" black miters-Autometer boost/pyro
"If you dont have ambition and big dreams, you end up working hard for someone who does"
95dieselsmoke is offline
post #5 of 5 Old 12-24-2008, 02:43 PM
tjl
tjl's Avatar
Had the same problem. The leak was caused by a broken bolt at the rear of the drivers side manifold.
'96 F350 CC dually 5 speed w/short throw shifter, '03 sd intercooler, stage 1 injectors, D66 turbo, 6 POS chip with Tony Wildman tunes, T500 HPOP, CCV mod, gutted EBPV, modded ID
tjl is offline
