Running ruff and power loss - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-16-2014, 08:11 PM Thread Starter
FT3
So about 6 months ago I bought a 1995 f-250 7.3l and it ran grate until I was an idiot and I ran one of the tanks completely empty (at least that's what I think did it). It started shaking when driving up slight inclines and has power Los and idles ruff. I changed the fuel filter but when I did it I noticed at the bottom of the filter housing there is about a eighth of an inch of black debri. Is this my problem and if so how do I flush this debri out? Do I need to clean my injectors or anything else?
FT3 is offline
post #2 of 3 Old 04-17-2014, 01:46 PM
Quoted: 725 Post(s)
Youll need to remove the fuel bowl completely and clean it out. But in doing so you will need to buy new orings for all the fuel line fittings. By then you may as well buy the whole o-ring rebuild kit from diesel-o-rings.com
Put it back in and fire it up. It will take a bit though to get the whole system bled and pressurized.
Corey@CNCFAB is offline
post #3 of 3 Old 04-21-2014, 07:59 PM
These older trucks are also known to have the fuel pickup screen break apart in the tank and plug up the suction tube with pieces of plastic.
JTWAT is offline
