Dual Tanks - Ford Powerstroke Diesel Forum
post #1 of 20 Old 03-26-2014, 04:59 AM Thread Starter
Dual Tanks
Is there a thread for troubleshooting dual tanks....1995 7.3..... ????
Buckeye_Joe is offline
post #2 of 20 Old 03-26-2014, 11:51 AM
Quoted: 43 Post(s)
Not in particular. Depends on what the problem is.
madpogue is offline
post #3 of 20 Old 03-26-2014, 02:55 PM Thread Starter
well, so far, not sure WHAT the problem is, other than when I test drove the truck before purchasing it, the guy told me the front tank was "empty"...since I wasnt sure if i was buying it yet, at the end of my test run I put 10 bucks in the front, flipped the switch and it went higher than it was....ok, no prob....So yesterday I was less than 1/4 on the rear, time to open the wallet and filler up....got 11 gallons in the front and 10 in the rear (supposed to be 18/19 gallons)...front showed 1/2 tank, the rear full(was snowing like a mofo and didnt wanna deal with it last night) , this AM when I left for work threw it to the front and it said 1/4 full, not wanting to risk running it out of fuel if there was a problem with it I threw to the rear for drive to work, left work tonight let it idle for about 30 minutes on front tank, then left work, drove about 10 miles out of the way and it never sputtered or anything, stayed at 1/4 tank...no spillage that I can see...
So my ultimate question is (1st dual tank diesel I have owned)....what is the stock setup for a 1995 ? where are the pumps/valves...may just be the gauges are stuck on the front and the rear may be sticking too....guess i may just drive til sputter and throw to rear and see how far she goes....
post #4 of 20 Old 03-26-2014, 03:19 PM
Quoted: 43 Post(s)
The only pump is the mechanical lift pump on the block, run by a 17th lobe on the camshaft. There's a valve on the frame rail; it switches both supply and return (therefore six connections). When the valve flips from one tank to the other, it throws a switch that switches the feed for the dash gauge from one sending unit to the other.
I have a PDF of the diagram from the EVTM at home; I'll post it later if I don't kill the brain cells carrying the reminder btw. now and then....
The gauge and senders are notoriously inaccurate. You may also have a problem with one or both filler necks, kicking the nozzle off before the tank is full. There's a mod for that, which also allows you to fill the tanks a LOT faster.
Pickups - front tank is 19 gallon long bed, 16 gallon short bed. Rear tank is 18 gallon.
madpogue is offline
The Following User Says Thank You to madpogue For This Useful Post:
Buckeye_Joe (03-27-2014)
post #5 of 20 Old 03-26-2014, 03:21 PM Thread Starter
awesome, thanks for the reply, yes its a long bed...forgot to mention that....
post #6 of 20 Old 03-26-2014, 06:23 PM
Quoted: 43 Post(s)
Here's the doc. If it turns out too cr@ppy to read on a download, try: http://userpages.chorus.net/elephant...nkSelector.pdf .
madpogue is offline
post #7 of 20 Old 03-27-2014, 04:03 AM Thread Starter
Thanks Again, last Question...what is this MOD for the fuel neck you speak of??
post #8 of 20 Old 03-27-2014, 05:22 AM
Quoted: 43 Post(s)
In a nutshell, you remove the inner hose, and run a small hose from the vent on top of the tank back to the neck; requires fabbing in a fitting for that hose. Do a search, here and on the other forum sites, for "fast fill mod".
madpogue is offline
post #9 of 20 Old 04-30-2014, 02:43 PM
Dzldust's Avatar
my rear tank runs out of fuel at around 14 gallons.
Dzldust is offline
post #10 of 20 Old 04-30-2014, 03:28 PM
Quoted: 43 Post(s)
^^^^ That's another problem. Common one. The "showerhead" (strainer on the end of the pickup) inside the tank has broken or fallen off. As a result, the pickup tube reaches only about 3/4 of the way down the tank, so the truck "runs dry" when you actually have about 1/4 tank of fuel in it. Solution - drop the tank (or pull the bed), remove the sender/pickup assembly (get a new lock ring; you're bound to trash yours upon removal), and replace this - http://www.amazon.com/E5tz9j306ba-Diesel-Ford-Sender-Strainer/dp/B0042HBSYE .
madpogue is offline
