crank no start - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-16-2014, 12:56 PM Thread Starter
crank no start
hey guys i have a 97 f250 7.3 i cranked the truck up yesterday morning and ran great came to work then went and changed the program from race to extreme and after that it will crank normaly but wont start the wts light and the check engine light will flash quickly i checked the #9 and #22 fuse there good checked the #2 relay its good but clicks along with the lights flashing and i checked the connections at the pcm and where the harness splits to go to the engine?
joe5264 is offline
post #2 of 7 Old 03-18-2014, 06:13 AM
Quoted: 71 Post(s)
What tune are you starting it in? I always put mine on the econo tune to start (which I am getting rid of soon). I'd start by pulling the tuner off and diagnose from there.
White95f250 is offline
post #3 of 7 Old 03-18-2014, 06:27 AM
Quoted: 44 Post(s)
ALWAYS revert to stock whenever possible, esp. with a no-start. If it's a chip, REMOVE it (don't just "turn" it to stock). If it's a programmer/tuner, re-burn the PCM to stock.
(Presence of chip/tuner is a good thing to mention in opening post. Sigs DO NOT count, as they're often disabled for space/time reasons.)
madpogue is offline
post #4 of 7 Old 03-19-2014, 03:48 PM Thread Starter
Well I figured it out I tryed to put it back to stock but it did the same thing I read where a few people said it wiped out there PCM and I calle edge and they sent me a stock tune to put back on the truck and a new tuner and it does fine now
joe5264 is offline
post #5 of 7 Old 03-19-2014, 03:58 PM
Quoted: 71 Post(s)
Good to know.
post #6 of 7 Old 03-19-2014, 04:19 PM
Check your oil level. Low on oil=no oil pressure= cranking with no start
USNavyPowerstroke is offline
post #7 of 7 Old 03-19-2014, 04:34 PM
Quoted: 44 Post(s)
This is why chip > programmer.
madpogue is offline
