hpop pros inside please! and thanks - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-19-2008, 04:08 PM Thread Starter
mustangz's Avatar
I have worked on quite a few of these things but this is a first for me. I have a no start 95. I have ae software and I am getting no pressure on the icp. It also had a few codes pertaining to that also. I looked in the reservoir and it looks to be empty. I tried putting some in it and I swear it sounds like it is running right back out! What do I need to check next? Thanks
mustangz is offline
post #2 of 5 Old 11-19-2008, 04:18 PM
psd
some 95s are like that.its in the front cover and changing the hpop and ipr valve would help.hows your oil level?thy to bump her and see if oil comes up?
if not low oil pressure pump may need to be replaced.
outlawdiesel is offline
post #3 of 5 Old 11-19-2008, 06:33 PM Thread Starter
mustangz's Avatar
Thanks for the reply! Anybody else?
mustangz is offline
post #4 of 5 Old 11-20-2008, 04:30 PM
bondsman's Avatar
Can you fill the reservoir or does it just keep drining out? It will take more than a quart to fill it.. You can check your low pressure oil pump by removing the oil pres sensor on top of the hpop res., install a guage and see if you can build oil pressure. If you cannot, replace the lpop.
That is how I determined mine was bad. I was able to fill the hpop and after extended cranking, the injectors would finally start clicking (until all of the oil in the reservoir ran out). I replaced the low pressure oil pump (it is behind the harmonic balancer) and is bolted to the outside of the engine. It was about $80. Changed it and it fired right up.
bondsman is offline
post #5 of 5 Old 12-04-2008, 09:07 PM Thread Starter
mustangz's Avatar
Thanks guys for the replys. First thing I asked the guy was did he check the oil. He said yes and acted offended so I took his word for it. I made me a gauge up for low pressure and high pressure and was calling him to come over and check it out. He said he checked the oil and it was 5 quarts low. I said fill it up and it would be fixed. Lesson #1 if you want something done you have to do it yourself! It is running well again but he wants me to find out where the oil is going lol!
mustangz is offline
