Starting problems please help - Ford Powerstroke Diesel Forum
Old 12-04-2006, 03:41 PM
Hi guys im new here and i have a big problem my 96 PS wont start, it will just crank and crank, but no dice, What i did notice was that no smoke comes out the tail pipe while cranking. The rpm gauge move a little while cranking, "I have new batteries. All fuses are ok, So what do you guys think is my problem?
Old 12-04-2006, 03:50 PM
did you try checking the fuel filter housing to see if it was full?
Old 12-04-2006, 03:52 PM
did you try checking the fuel filter housing to make sure the fuel pump was working?
Old 12-04-2006, 03:55 PM
yea, i drained the housing, and i tried restarting, and i checked it again. and it was full again
Old 12-04-2006, 04:00 PM
sounds like a fuel delivery problem from fuel filter housing to injectors
Old 12-04-2006, 04:02 PM
do you think that it could be my starter? I feel that it could crank a little better
Old 12-04-2006, 04:06 PM
I don't think its the starter, because if you were getting fuel, white smoke should be coming out of the exhaust.
Old 12-04-2006, 04:07 PM
have you tried pulling any codes from the pcm?
i havent tried pulling codes but i did put a new CPS in
Old 12-04-2006, 04:09 PM
did putting in the cps change anything?
