Help, big leak - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-15-2014, 04:34 AM Thread Starter
7.3workacholic's Avatar
Help, big leak
I rolled up to the gas station this morning, and all of a sudden some type of fluid started pouring out from under my belt and hpop, I have no idea what it is, Its not oil or fuel, I have a feeling it's power steering fluid, I put gas in her, and drove over across the bridge no problem, idk what the heck it could be.
ID:	257769   Click image for larger version
ID:	257777   Click image for larger version
ID:	257785   Click image for larger version
ID:	257793   Click image for larger version
1997 F250 7.3 E4OD Centurion XLT 2wd, afe prodry s intake, diamond eye down pipe dump, tonys tunes, fpr shim, swamps idm, de-stickered and molded, smoked headlights,heavy duty rear suspension, Gearvendors, 2in level, 18in xd hoss on 35in terra grapplers, 8x8 steel rear bumper, in the process of black on whiting her
7.3workacholic is offline
post #2 of 7 Old 03-15-2014, 06:57 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Check and make sure the cap is still on the Power Steering Pump Reservoir and also make sure that the high pressure line has not popped out of the pump (they like to do that). Cheers!
Patrick Feeley is offline
post #3 of 7 Old 03-15-2014, 05:32 PM
midnite rider's Avatar
Quoted: 285 Post(s)
hope u didn`t put gas in it like u said haha, but it is one of 4 fluids, oil, fuel, coolant, or ps fluid.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #4 of 7 Old 03-15-2014, 05:36 PM
speedracer7c's Avatar
looks like rusty coolant to me.
97 F350 Reg cab XLT 7.3, ZF5 Swap, Diamond eye 4" turbo back,Riffraff 6637, Deleted pedestal and outlet, riffraff billet wheel, Baby Swamps, Ts 6 pos with swamps tunes Glow shift triple gauge pod
340k miles and kicking!
2016 F-250 Supercab 6.7
speedracer7c is offline
post #5 of 7 Old 03-15-2014, 05:47 PM
Quoted: 285 Post(s)
Sounds like water pump might be on its way out.
-Tom
post #6 of 7 Old 03-17-2014, 04:23 AM Thread Starter
Yep it was the water pump, replaced it Wednesday, went pretty smoothly
post #7 of 7 Old 03-17-2014, 08:35 AM
very nice glad it went smoothly for you
