low boost pressure?
When cruising on the highway 55-60mph the needle on my boost pressure barely leaves the zero mark. The highest I've seen it go was around 5-7 and that was goin up an incline pretty hard. Any suggestions?
Also what's this cps recall that was supposed to be for our trucks? Thanks |
The cps recall is simple.....take your teuck to your local friendly ford dealership and tell them you got a cps recall and they will give you a new one. What was the highest boost you saw with the TW? I have seen as high as 27 with it my truck, when crusing it's normal to see 0 boost the turbo only builds boost when the motor is in a pull.
where is your boost guage installed at?
Did a shop install the guages or was it done in the driveway? If it was done at a shop I would take it back have them fix the trans guage and look at the boost guage. I could build 12-15 all day long with the 1705. I would think you could build at least 10.
lol I'm not sure. I know nothing about my truck. I'm not even sure how to locate where it is installed at.
A guy installed it for me that I met at a truck pull event and it was at his house, but he runs his own business in his driveway I guess? I trusted him becasue he built his own truck from the ground up and he intalled gauges on a obs before
not that it matters or not but on my street tune i can accelerate at 3/4 throttle and hit over 30 psi, i floored it once and saw 38 and i backed off quickly
Check to see if it is spliced into your map sensor line, thats the best place to put it in an OBS
