Speedo Not workin - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-13-2008, 03:57 PM Thread Starter
Dallas4x4's Avatar
Speedo Not workin
Well when i bought my truck last year the oringal rear axle needed a new pinon bearing and posi among other things. The shops wanted $1200 for that job. So i ended up on putting a rear axle out of a 1993 F250 with 163kms on it.(Sterling 10.25") It had 4.10s and the posi was still reasonbly tight.
It bolted in no prob and is still working fine todate. But the speedo doesnt work now. I got a new connector for the VSS on the axle but still wont show how fast im going. Kinda annoying. Any ideas on how i would fix it? I kinda would like to know how fast im going by looking at my guages.
1994.5, 2.5 lift, 35s on 17x10 MHTs, Intercooled, Stage 3 injectors, Nitrous, 6637, Water/Meth, 3" DP, 4" Magnaflow, IDM, TS Chip, 4.10s, 33s, 4 Pod pillar. 6000k HIDs.
Converted From ZF5 To E4OD w/ PCS TCM-2000 Tuneable Trans Computer, 6.0L Trans cooler and Triple Disc TC.
Up next Install electric fuel, ladder bars
Dallas4x4 is offline
post #2 of 9 Old 11-13-2008, 04:39 PM
lifetime member
subscribed
january 2003 6.0 F-350 Lariat 4x4 cc with 08 long bed. recon cab and mirror lenses, torqueshift(reman on 9-03-09) with three disc billet convertor(500 rpm lowered stall speed),mag-hytec deep tranny pan,, 8" fabtech lift w/ 37" iroc super swampers on helos,pro comp ladder bars, custom sct x3 with tunes by eric @ innovative diesel, boost and pyro,edge insight, afe, 4" straight piped, ARP headstuds, banks intercooler & high ram intake. engine mods & maintenance by first coast diesel performance.
nsrchofpwr is offline
post #3 of 9 Old 11-13-2008, 05:19 PM Thread Starter
Dallas4x4's Avatar
I took the VSS out of the axle and cleaned it. still doesnt work
post #4 of 9 Old 11-16-2008, 01:22 AM
Hey man any tips on getting the VSS off, mine is stuck i unbolted it and i can twist it about a 1/4 turn but it will not come off!!! Am i missing something? sorry to thread jack.
Justsomeguy81 is offline
post #5 of 9 Old 11-16-2008, 01:03 PM Thread Starter
Dallas4x4's Avatar
its held in by a o ring. Put a flat head screw driver between the VSS and the axle and pry the VSS up. It should just Pop right out
post #6 of 9 Old 11-16-2008, 01:05 PM Thread Starter
Dallas4x4's Avatar
Well I put a new VSS in place. ABS light and speedo still doesnt work....
post #7 of 9 Old 11-26-2008, 02:30 AM Thread Starter
Dallas4x4's Avatar
Now i tried new fluid and cleaning the axle out. And put on new pig tale.
Any ideas???????
post #8 of 9 Old 11-26-2008, 02:33 AM Thread Starter
Dallas4x4's Avatar
OR how does the speedo mechinasm work?
post #9 of 9 Old 11-26-2008, 02:46 AM Thread Starter
Dallas4x4's Avatar
Im going to goto ford and ask them. See if they know what would be the problem
