Skipping gears quickly. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-06-2014, 09:58 AM Thread Starter
Hey all,
Truck feels like its skipping gears under normal acceleration. First gear is fine then seems as if it goes into second for a second then goes straight for third which drops the revs to almost a stall.
Also, seems like my truck can't decide what gear to go in going uphill and constantly changes between 2 gears.
What could this be?
Its a 96 powerstroke F250 automatic.
Thanks in advance.
Rob73 is offline
post #2 of 6 Old 03-08-2014, 09:17 AM
Quoted: 44 Post(s)
4x4 or 2wd?
madpogue is offline
post #3 of 6 Old 03-08-2014, 09:37 AM
Gene's Avatar
Quoted: 3 Post(s)
I know this sounds like a stretch, but I had those problems on a 99 chevy gasser many years ago. Problem turned out to be a clogged fuel filter. The truck would continually hunt gears because it couldn't get enough fuel through to filter to keep the transmission engaged properly.
Not a clue if that's your problem, but it is an easy check.
Gene
2001 F350 Crew Cab Long Bed 4x4 6 speed
PHP Hydra, 4 inch MBRP Exhaust, GTP38R, FRx, DIY Exhaust Brake, T500 HPOP, Hutch/Harpoon,
6-liter Intercooler, 6637, DIY Coolant Filter, CCV Mod
Gene is offline
post #4 of 6 Old 03-08-2014, 02:23 PM
Mine was doing it. Turned out it was the rear abs sensor.
TheMaineMan is offline
post #5 of 6 Old 03-08-2014, 04:49 PM
midnite rider's Avatar
Quoted: 285 Post(s)
Do u have cruise control, if so unplug it from the master cylinder then try. If that doesn`t work check the fuses for the towing package, u could be back feeding through a ground. i think i explained that right. haha
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #6 of 6 Old 03-12-2014, 08:45 PM Thread Starter
Originally Posted by madpogue View Post
4x4 or 2wd?
4WD
Fuel filter is 2 months old, but maybe tank filters?
Hmm.... how so?
Explained it perfectly but its not engaged, I will attempt it either way this one this weekend.
Rob73 is offline
