Engine Coolant Leak
Hi,
My 1997 F-350 has started leaking coolant. It is at the front of the engine down by the harmonic balancer. The coolant seems to be coming from between the engine block and that flange. I would have thought oil would leak from that area and not coolant. But, I not very familiar with how these engine work. Check out the pictures below. The truck has under 75,000 miles on it so I am hoping it is nothing major. Thanks you in advance for your guys help. Chris |
looks to me like the coolant is coming down front water pump you can see the trail down the side. nothing major.
yeah i'd definitely say the water pump. pretty easy fix on mostly any 8 cylinder front ways motor vehicle.
