over filled tank? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-26-2014, 04:47 PM Thread Starter
over filled tank?
Hey everyone, I just filled up the rear tank on my truck and after driving about 15 miles I stopped at the store to pick up some groceries. As I was coming back to my truck I noticed what looked like a water fall coming from the fuel door. I switched the tank to the front one then drove it back home. When I got home I switched it back to the rear while the motor was running and opened the cap real fast to let loose all the pressure that was making the fuel leak. I drove the truck around the neighborhood and checked it again and it was not leaking anymore. Could I have just over filled the tank? I did notice the needle was quite a bit passed full. Thanks for any input guys!
powerstroker5073 is offline
post #2 of 11 Old 02-27-2014, 02:08 PM Thread Starter
Anyone? I really need the help, I'm thinking it's just the vent but would it shoot out the filler cap like that? Maybe I just need a new cap?
post #3 of 11 Old 02-27-2014, 04:06 PM
midnite rider's Avatar
Quoted: 285 Post(s)
Probably to full and expansion forced fuel out of the cap. You may need a new cap as well.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #4 of 11 Old 02-28-2014, 05:17 AM Thread Starter
Thanks I think that's what the problem is too and I'll go ahead and buy a new cap as well.
post #5 of 11 Old 03-02-2014, 08:55 PM
Maverick1701's Avatar
Send a message via AIM to Maverick1701
if it keeps acting up sometimes the tank switch can get jacked which causes one tank to fill the other to the point of overflowing.
It sounds like you have it taken care of though.
ChrisChris
2003 Kawasaki KLR650
1997 Ford Expedition 4x4
1967 Kaiser Jeep M35A2 6x6
2016 Silverado 4x4 Crew-Cab LS/Police
Maverick1701 is offline
post #6 of 11 Old 03-04-2014, 12:00 PM Thread Starter
I just filled it up again but just the rear and it hasn't done it. If it were the switch how do u fix it
post #7 of 11 Old 03-04-2014, 03:55 PM Thread Starter
Turns out my front tank is feeding the rear because I was running the rear awhile and noticed the needle getting higher, switched to the front and it was at 1/2 when before it was at 3/4 so I guess it is the switch. How is it fixed?
post #8 of 11 Old 03-04-2014, 04:17 PM
check out this thread from FTE:
Fill Up Front Tank Goes To Back Tank Fill Both Gas Comes Out While Driving - Page 4 - Ford Truck Enthusiasts Forums
Also check out ford recalls: 93S68 and 00S57
ChrisChris
post #9 of 11 Old 03-04-2014, 04:18 PM
Quoted: 285 Post(s)
THen it is probably the switch valve on the frame that when bad. check the connections for corrosion be for u do anything, so u don`t spend any money. this winter has been a *****, all though i don`t no where you are from.
-Tom
post #10 of 11 Old 03-04-2014, 04:33 PM Thread Starter
I'm from south Texas and it has been cold but nowhere like up north. When you say check the connections do you mean fuel lines or electrical? About how many mpgs are common with a truck like mine because I figured at maybe 15mpg with a 19 gallon tank will give me 285 miles a tank. Hell that ain't too bad running with just the rear because that's about the same as my mustang lol.
