Irratic idle - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-03-2008, 11:14 PM Thread Starter
Shaking the Bush Boss
CHUCK's Avatar
Irratic idle
well, coming home from work, check engine light came on. I lost almost all power, pedal to the floor, shed barely pull herself. Jumped up to street tune, did alittle better. Once I got home, back to stock tune, and she idles irraticly. Watching the aux idle controler....550rpm-780rpm....that much drop. Guess I'll be pulling codes when I wake up!
Just got her back together yesterday....fuel bowl issues. Drove her yesterday about 50 miles, and 20 miles to work. No problems.
Chuck
CHUCK is offline
post #2 of 6 Old 11-04-2008, 10:01 AM
glad you got it figered out.
1997 F250 XLT CC PSD 4X4 4.10LS E4OD (AB CODE TRUCK)
DFUSER 18K MOD
4" TURBO BACK DI EXHAUST
1705 SUPERCHIP
DIY INTAKE
2" LEVELING
GAUGES,EGT,TRANS,BOOST,OIL TEMP,OIL PRES,WATER,VOLT
SONNAX VALVE/TRICUMULATER SPRINGS
30,000lb TRANS COOLER:
SWAMPS IDM
1996 F250 XLT EC PSD 4X4 4.10LS E4OD
1705 SUPERCHIP
DIY INTAKE
DB EXHAUST BRAKE
30,000LB TRANS COOLER
QUAD POD WITH EGT,TRANS,BOOST,WATER
140V IDM
ono_55 is offline
post #3 of 6 Old 11-04-2008, 10:51 AM Thread Starter
CHUCK's Avatar
Havent got her figured out. I went and borrowed a freinds OTC scan tool. I pulled the codes... nothing out of the ordinary. Same codes I get every time... ebpv not working (unpugged), ipr erratic signal uncontrolable (its got a fooler hooked to it).
The one that gets me is the oil temp sensor ckt. it wouldnt let me do a contribution test. Granted, The truck sat all night, and was not up to temp when I started the koer test.
She did idle better this morrning.
Chuck
CHUCK is offline
post #4 of 6 Old 11-04-2008, 10:59 PM Thread Starter
CHUCK's Avatar
update with codes.....any help?
codes p1211
icp not controlabe....Think its do to the tuner
p0476...ebpv not controlable...its unplugged
p0196...eng oil temp sens ckt...have no idea.
Chuck
CHUCK is offline
post #5 of 6 Old 11-05-2008, 08:51 AM Thread Starter
CHUCK's Avatar
bump up....
Chuck
CHUCK is offline
post #6 of 6 Old 11-05-2008, 08:55 PM
Shade tree mechanic
95dieselsmoke's Avatar
codes p1211
just throwing this out there, and bumping this up, perhaps your EOT sensor?
MATT
Now featuring a 6.4 fat bottum 6 speed
95 f250--238k and counting
RDS stage I's-TW live tuned-Dana 60 swap-9" lift/40x13.5x20 ProComps-ZF5 swap/short throw/South Bend CON OFE-Iron Bull front-AFE CAI-SD innercooler-Fab Tech traction bars-MBRP DP/6" black miters-Autometer boost/pyro
"If you dont have ambition and big dreams, you end up working hard for someone who does"
95dieselsmoke is offline
