Clutch pedal goes to the floor? - Ford Powerstroke Diesel Forum
Old 11-02-2008, 03:37 PM
I know we've covered the clutch-pedal-bushing issue for pedals that go all the way to the floor, and but how about one that goes to the floor... and STAYS THERE?!
I just got done with the clutch job this weekend, my wife helped me bleed the clutch and it went into all gears, so I called it good. But now twice, the pedal has gone all the way to the floor, and stays right there! I had to flick it up with my toe, and on the next pedal stroke, it was fine. Fortunately, both times it happened at a stop.
Did I miss some air in the system somehow? I followed the standard bleeding procedure (pushing the slave cylinder to force the fluid and air back up the line), which seemed to work, but if it happens mid-shift while on the road, it might be an issue! Any suggestions?
Old 11-08-2008, 05:26 PM
i ran into this problem on my old 94 turbo idi... went through three slave cylinders within 4 months... it ended up that someone before me installed the wrong slave cylinder, went up to ford shop and got the right part.. never happened again..
Old 11-10-2008, 09:08 AM
Well, as it turns out it must have been air in the MC. We just got back from a trip to Missouri, and apart from the alternator seizing up (just AFTER we got there, praise God!) and eating the fan belt, we had no problems. Not a single problem with the clutch since then, so I guess it's solved.
Old 11-13-2008, 03:54 PM
That happens to me all the time. Always when im racing some one. Clutch petal sticks to the floor and I loose the race! And thats with a New clutch, new single mass fly, new slave cylender, new hyd line, and resivour and atchuator. Its reallllll annoying.
