95 problems, need quick help - Ford Powerstroke Diesel Forum
Old 11-02-2008, 06:30 AM
Hello All
my truck has a knocking noise and runs real rough at low rpms. It has a hard time getting going under load, like it is choking out. Idles rough. It started having blue smoke at times a few months ago, which has gotten slowly worse. The fuel filter has been black the last couple times I changed it drained fuel bowl and it looked greenish gray. No cel and nothing changes when I unplug icp. Changed cps already, and all the fuel and air is clean and flowing well.
From my research here at the org it seems everything is pointing to injectors.
No access to diagnostic tools
Need help quick, gotta make a living with this pickup
Thanks
Old 11-02-2008, 07:39 AM
Illiana Chapter Director
Originally Posted by Aaron Dickinson View Post
Hello All
Thanks
Injector o-rings probably split and leaking. Will have to pull injectors and install an o-ring kit.
Old 11-02-2008, 07:49 AM
ya i was going to say injector problem but i no that suffy said one time that i counld be a broken push rod but dont remember the simtems. but to me sounds like a injector problem of some sort.
Old 11-02-2008, 09:22 AM
thanks guys
where is the best injector removal/replacement write-up?
Old 11-02-2008, 09:25 AM
thanks guys
See if this helps you out.
Injector replacement instructions
Old 11-02-2008, 01:05 PM
figured out at least part of the problem, the plug on the intake was unplugged
but I still think my o rings are needed repair. Will it harm the engine to run it for a while with bad o rings?
Old 11-17-2008, 05:07 PM
Send a message via AIM to Maverick1701
Did you check your oil level? The injectors dont run very well w/out oil....my old white truck (sold) was having similar problems eventually I found out that it had been burning oil and was running so low it didnt have enough oil to fire the injectors....FAIL
