long cranking to start
1996 ford F350 7.3 The truck will start every time but only after cranking it for about 10 seconds.
There are no codes coming up ont he computer. I have noticed that the injectors are not firing for the first 10 seconds and as soon as they do the truck fires. Glow plugs, relay, hpop, pcm, fuel pump have all been replaced very recently. Any ideas? |
batteries??
No batteries are good and cranks fast the injectors are not starting until the 10 seconds of cranking
crank position sensor
[CPS has been changed as well
How many miles? HPOP may be taking time to get the pressure up. Needs 500-550 psi before the computer turns on the fuel.
Check your flex lines (rubber or synth) in the fuel route. I know that with old Jeeps, if you have a cracked hose or a rust hole in a hard line, that will allow the fuel to bleed down, keeping the thing from starting up right away (or staying started, with older carbureted units) because the fuel isn't right there and ready to go. Just a thought.
Sounds to me like the HPOP is bleeding off.
id check the idm,injector driver module.
injector o-rings, the top o-ring will go out and let HPO to blow right past. you have to have aleast 500 psi of HPO to start
