Wheel bearing? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-19-2014, 10:04 AM Thread Starter
Wheel bearing?
So I have 95 f250 and I get grinding noise and can feel it pedal. When I put load on right tire aka a turn it grinds hard. I'm thinking wheel Bearing, anyone have write for auto hubs?
Matticus is offline
post #2 of 6 Old 02-25-2014, 06:24 PM
mjones3586's Avatar
I'm having the same problem with mine just narrowed it down to wheel bearing I'm gonna do inside and out plus spindle bearings but have manual hubs gonna do a write up for some ppl
"Diesel Head and Machinist"
4 inch lift o 36"s
3"DP to 7" Mitre Cut Stacks no cat/muffler
mjones3586 is offline
post #3 of 6 Old 02-25-2014, 06:53 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Mine is 2wd, but had a more pronounced grinding when turning onto the bad bearing.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 6 Old 02-25-2014, 06:57 PM
Jeff-F350's Avatar
Quoted: 14 Post(s)
2004 F250 Super Duty 4x4
Good write ups.
Jeff-F350 is offline
post #5 of 6 Old 02-25-2014, 07:08 PM
Powerstroke_21's Avatar
im having a similar problem and there is some slop in the ujoint, so i'm thinking that thats what it is. its getting replaced this weekend and ill see if that fixes it, if not im going to check the wheel bearings. I'm hoping its just the ujoint. Also when I was checking it today, I locked the hubs and lifted the drivers side front tire off the ground and checked it and when I spun the wheel, there was a little lag with the axle, same with the passenger side, is this normal?
Jarrette
1999 F350 ecsb 4x4 130k miles.
Mbrp 5" exhaust
TS 6 pos chip with Gearhead tunes
Auto Meter CS Series gauges (boost, pyro, trans temp)
S&B Intake
Aftermarket wastegate controller
Mods to come:
Crank case vent
Hutch and harpoon mod (if not already done)
1997 F250 rclb 4x4 gasser
Going to do a 12v swap in it tho
Powerstroke_21 is offline
post #6 of 6 Old 03-12-2014, 03:24 PM
hey OP just wondering if you found out what it was? mine made a noise for 2 or 3 days but after the first day I unlocked the hubs but then after 3 days it went away. just put it in 4wd cuz of the snow and I think the noise came back. when i took it to the shop the guy said the wheel ujoint was fine which is what I thought was the problem and when I picked it up that's when the sound went away
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
