ABS Light
Code 12. Loss of fluid during an ABS stop or something or other. cant remeber pulled the code a long time ago so im not exactly sure on the definition. ABS light is always on, sometimes it takes a little while for it to come on but its always on as the truck is in motion.
my red brake light works with the parking brake set. The float in the rez seems a little bit sticky though. Any ideas? |
so you're actually losing fluid with the abs light up? thats strange.
no no, there is not a single leak in my braking system
well it's probably the abs sensor more than likely. i don't think it does anything, but causes the abs feature not to work. honestly i could care less about anti lock brakes, and if mine went out i wouldn't even rush to change it.
but if it was the abs sensor itself wouldnt it be throwing a different code?
