starts up then rough idle w/ CEL on
I've had the truck for almost 2 years with no problems. 95 powerstroke auto 4x4 all stock except for a cold air kit. Put it up for sale 1 month ago and then glow plug relay died 2 weeks ago. Replace it ran fine. Today took it to get it undercoated and when i started it up at the garage it fired up fine then started loping big time with check engine on. Stayed like this for about 1 minute or so. It would die out if you don't keep your foot on the pedal. Then like you flipped on a light switch the check engine goes out and it goes into its normal purr. When its running bad it has no power. Got it home and seemed ok. Went back a few hours after and started it up and same thing. Ran bad for about 1 1/2 min with check engine on. Then goes out and runs fine. Drove about 2 miles to get diesel shut it off same thing when i went started it yet it only lasted 15 seconds. Got it home shut it off and started it and it ran fine. Seems worse the colder it is. If it was the cam sensor the tach would go nuts and not move during cranking right?
I'm thinking that it was a coincidence after having it under coated, but ??
I have a code reader that says its good from fords 81-95 diesel included. The plug under the dash does not look like the same fitting, but i'll go try.
Will it store the code in memory after the light goes out? really don't want to buy a scanner as I'm trying to sell the truck.
Thanks guys
