Led bulb in taillight problems - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-13-2014, 06:36 PM Thread Starter
7.3powerstroker's Avatar
So I ordered all clear taillights which means I need a red bulb. So I put some red led bulbs in there. They worked for a day or two and now they only work when I press the brake pedal. They won't come on as running lights. So I changed the bulbs again and same thing worked for a couple days now back to same problem. Only come on when I press the brake pedal. The running lights don't work. Wondering if anyone else has had this problem. It also doesn't work when I try and use the turn signal. Could just need a simple
Resistor or maybe it's a relay in the truck of some sort.
Help would be much appreciated. I'm sure someone else is trying to run LEDs in the rear
Sent from AutoGuide.com App
Shelby
1995 F350 7.3l
5 speed
240,000km
DIY Intake
3.5"dp to 5" straight pipe
99 Turbo and Spyder
6" Lift
37" BFG KM2's
Harley Davidson Leather buckets
Grant Steering Wheel
Autometer Gauges Pryo,Boost
CB Radio
Custom Bumper(built it myself)
Clear Headlights (black background)
Black Grille and Headlight Trim
Soon to come
Custom Rear Bumper
Headache Rack
6.0l intercooler (already have one just need to pipe it)
rosewood stage 1's
custom tunes
7.3powerstroker is offline
post #2 of 8 Old 02-16-2014, 05:32 AM
delta99's Avatar
I think you need to replace the flasher for an led specific one
http://www.superbrightleds.com/morei...asher/784/838/
2000 F250 Super Duty, 4x4, 7.3, 6 speed manual, 4" straight exhaust, 6637 air filter, superwinch hub locks, zoodad, foil delete, AIH delete, power pedal, autometer gauges, 2.5" leveling kit, 260,000
delta99 is offline
post #3 of 8 Old 02-16-2014, 09:38 AM Thread Starter
I just ordered one off eBay for 12 bucks. I hope this clears up the problem
Shelby
1995 F350 7.3l
5 speed
240,000km
DIY Intake
99 Turbo and Spyder
6" Lift
37" BFG KM2's
CB Radio
Soon to come
Custom Rear Bumper
Headache Rack
rosewood stage 1's
custom tunes
post #4 of 8 Old 02-16-2014, 12:49 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
What brand of LEDs did you use?
There are a lot of cheap leds out there that I would not trust, if they worked correctly at first, then started acting up, I would say that they are not very high quality leds.
I use leds mostly from vleds: Automotive LED Lights | LED Driving Lights | LED Lights For Cars
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #5 of 8 Old 02-16-2014, 01:17 PM
belz's Avatar
Quoted: 70 Post(s)
Where did you find the clear lights? I run the spider style led bulb and love it. Make sure u have the bulb for the right socket. Standard or ck I think are the two types of sockets. The grounds are in different spots. U can fix it by moving the wire leads on the bulb around.
belzfone
Belz
CPA Director
belz is offline
post #6 of 8 Old 02-17-2014, 05:16 AM
Quoted: 50 Post(s)
The flasher operates the signals, NOT the parking lights / taillights.
Do the rest of the parking lights work? Do the dash illumination lights work?
What number are the bulbs?
madpogue is offline
post #7 of 8 Old 02-17-2014, 05:58 AM Thread Starter
Yeah all my other lights work fine. I just out my stock tail lights and bulbs back in and they are fine. So I'd must be something to do with the LEDs.
The bulbs are 3157
Shelby
1995 F350 7.3l
5 speed
240,000km
DIY Intake
99 Turbo and Spyder
6" Lift
37" BFG KM2's
CB Radio
Soon to come
Custom Rear Bumper
Headache Rack
rosewood stage 1's
custom tunes
post #8 of 8 Old 02-17-2014, 07:25 AM
Quoted: 50 Post(s)
It _shouldn't_ matter (it doesn't matter with the better quality LEDs), but try turning the bulbs 180 degrees and reinstalling them. If that doesn't fix it, then I'd say yeah, the taillight / "dim" function of the bulbs has failed on both.
madpogue is offline
