Need your opinion please, techs help would be appreciated - Ford Powerstroke Diesel Forum
Old 10-27-2008, 04:23 PM
BOSS LEVEL
I have a 97psd that’s putting the coolant into the oil.
The oil cooler has been changed with new rings,
New water pump,
New injector rings
New head gaskets
New driver head
So far I have not seen oil in the coolant. But coolant in the oil, slime under the valve covers, white tip on the oil dipstick, and some white blow by.
I only put about a 100mi on the engine and the oil that was in it. Should I put new oil in it and drive some more and see what happens, get it pressure checked, or pull the engine, tear it down and check the block and front cover gasket?
Could the block be cracked?
How long does it take the oil to turn black?
Its only been 40,000mi since its been rebuilt.
Old 10-27-2008, 05:58 PM
BOSS LEVEL
Old 10-27-2008, 06:06 PM
ADMIN AND TECH
pull the water pump and look at the front cover itself real good , i have seen the cover actually get pitted from the water swirling around in behind the pump and eat a hole in the front cover, not saying thats the problem, but sounds like a place to look , 100 miles isnt that many miles for the repairs that were done, you had another thraed on this problem, did you change the oil and clean the valve covers since the last thread
Old 10-27-2008, 06:18 PM
BOSS LEVEL
since the last thread, the oil cooler was bolted on the engine, the valve covers were cleaned, new oil and anifreeze was added.
heres the font cover
Old 10-27-2008, 06:20 PM
BOSS LEVEL
i just drained the oil and filter today for the next clean oil cycle and it was tinted green. the oil filter had a small streak of green coolant.
however, the coolant remains clean.
i will be taking the valve covers off this week or weeken to clean them and the breather also.
Old 10-27-2008, 06:24 PM
BOSS LEVEL
im just askin because i dont know the next step.
i was wanting to pull the engine and tear it down and have it checked by a engine shop. but b4 doing that, i was wanting to know if there is any thing else i should do b4 i get to that point.
Old 10-27-2008, 06:25 PM
ADMIN AND TECH
i dont understand the oil tinted greendeal, oil and antifreeze dont ix and if it does it will sludge up but doesnt turn green , the front cover does look fine from the picture , as many reoairs has been done to this truck, all the repairs allowing some oil and coolat mix , im thinkin it needs to be driven more to determine if there is a problem
Old 10-27-2008, 06:58 PM
BOSS LEVEL
so your sayin fill it back up with oil and drive it like more than a 100 miles?
heres a pic with green tinted oil. normally the rotella 15w40 is brown. add some anifreeze, mix it and you get green oil. the coolant system had slime in it at one point but was washed with the cascade and now is clean. the radiator was blocked like 20% from what the radiator shop said as it was being rebuilt.
Old 10-27-2008, 06:59 PM
BOSS LEVEL
my only worry driving it a lot is that the breather clogs up and over flows into the turbo, and the concern for the injectors. they have 40k on them and dont wana buy new ones at the moment.
Old 10-28-2008, 11:30 AM
BOSS LEVEL
i called the mechanic and told him whats been going on.
he said first, fill back up with oil and drive it again. 100mi is good enough to figure out if the problem still exists.
if so, drain while hot, pressure check the cooling system. to do that jack up the engine in the body and drop the oil pan.
he didnt know if the turbo needs to be removed to jack it up.
does it? i think it needs to be removed to do that.
with the oil pan removed, pressure check the coolant system and look for leaks.
