fpr clean or new?
OK ive got the filter bowl and regulator off the truck... I have the pdf on the heater update.. ive call ford and IH about parts. now i need some advice..
1. Should i try to clean or replace my fpr. see pictures below * what does the tube from the bottom of bowl to bottom of fpr do and what about the steel wool look alike in the fpr, where the tube enters the regulator, do.. * please some feed back on my screen condition! 2. how important is this heater? when is it on, ive heard it can be done with out in warm climates does this effect starts or is this a go down the road ambient temp triggered heater. trucks all ready difficult to start. ![]() ![]() ![]()
OK I checked and cleaned what little bit of stuff was on the screen out. I was going to check the fuel heater, but. How do you remove the plate in the bottom ot the fuel bowl that the filter sits on? By the way the work I did last week made a HUGE difference.
i made a wrench by welding a pipe on a socket to losen the filter stem it been a long time that i had to remove the heater but i do believe it left hand thread mabe some one can verify that
Well I guess I need to do it again. Im thinking I need to remove the snap ring? Is there a screen in there? The only one I cleaned was the little one between the regulator and fuel bowl.
I dont know if I have to remove the heater. I just wanted to look under the filter plate, just to see how it looked under there.
to clean it realy good you need to remove it i clean mine in the truck use laquar thiner or carb cleaner and let it sit in there and get what you can get
by the way that is one nasty fuel bowl the one i blew a hole in from corrosion is cleaner than that 200.00$ plus i learned to clean it ever now and then
Here I am posting to the wrong thread! LOL
This is the problem I started a thread for and this thread was linked to it. |
i agree, that is really filthy man.
this is a link to all the info on this housing PSD Fuel Heater Upgrade page 3-3.pdf
