Wont Start!!!! - Ford Powerstroke Diesel Forum
Old 11-28-2006, 05:42 AM
Wont Start!!!!
Hey guys!! I left for about a week for Thanksgiving and I came home and now my 96 PS won't start!!!??? Before I left, I had just installed a cai, Turbo back exhaust, Guages, and a TS switch. It was running fine when I took it back home before I left?? The only thing I notice different is that the "wait to start" light does not come on when I turn the key on? It cranks and cranks and cranks, but never gives the hint that it wants to start. HELP!!!!!!!!!!!! Thanks in advance!!!!
Old 11-28-2006, 05:52 AM
I don't know nuttin....
Does the Tach more when cranking?
Check to oil level in both the sump and the HPOP.
The wait to start light no coming on makes me think a fuse....
Old 11-28-2006, 05:57 AM
ADMIN AND TECH
check the fues for the fuel heater also controls pcm
Old 11-28-2006, 06:08 AM
Powerstroke Techie
Yes check your fuses, in the engine compartment, i think it's fuse #22 30 amp. If it's blown probably need a new fuel heater. Or unhook the fuel heater and replace the fuse
Old 11-28-2006, 08:19 AM
Thanks for the help guys!! I'll try these and see and let ya know!!!
Old 11-30-2006, 05:46 AM
Dj!!! Man, You are awsome!! Sure enough, that 30 amp fuse was blown!! Replaced it and clack clack clack it fired right up I appreciate the help guys!!
Old 11-30-2006, 05:58 AM
Powerstroke Techie
Make sure you check your fuel heater, most likely it has come loose inside the filter housing. If you just leave it you will blow another fuse or worse melt the wires that go to the heater.
Old 12-02-2006, 03:49 PM
was in my driveway moving my 95 f-250 5sp and it just died, no glowplug light and keeps blowing that same fuse, , i will check heater thanks you guys
