help with smoke when cold - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-09-2014, 03:04 PM Thread Starter
OK so I got a 97 7.3 with 130,000 miles.the past 20k miles its been Smoking blue when cold and has a little bit of a miss to it when its cold until it gets to operating temperature and doesn't have quiet the power it use to have and doesn't get as good mpg..and when its 40f or under out it WILL NOT start unless the block warmer is plugged in overnight..the mods on the truck are new stock turbo straight pipeed super chip so its pretty much stock the truck does not burn any oil at all..and when I say it smokes when cold its not just a little bit of smoke but it looks like a Forrest fire is happing in my neighborhood lol. Thanks for any help just curious on what to replace guessing all new injectors and glowplugs? Could it be just glowplugs?
97bluepowerstroker is offline
post #2 of 4 Old 02-09-2014, 03:18 PM
Start with glow plugs or possibly just the glowplug relay and get the italian motorcraft ones autolites tend to detonate the tips on the cylinder. Loss of power mpg could be winter fuel. If new gps or relay dont help. Do the injector orings. The injectors dont tend to die very often. . To check gp relay as soon as you turn key on the volt meter should pull down hard. Whenever i buy a obs first things i do is gp relay glowplugs and injector orings.
Joe
____________________________________________
1996 SCLB 7.3L Auto - ZF5 Swap, E-Fuel, Baldwin air, 10k Mod, Rosewood Stage 1s, 17* HPOP -=-Sold-=-
1996 CC 7.3L Auto - Banks intercooler " 2 grand its home 6-28-13 needs Fpump and redone exhaust manifolds. to be finished soon
1967 Ford Fairlane 390and FE BBlock - 500HP playtoy
2012 F-150, bone stock.
96strokerlb is offline
post #3 of 4 Old 02-09-2014, 03:25 PM Thread Starter
Yea im gonna start with glow plugs. They have never been replaced and I don't drive it in winter the power loss and mpg loss is in the mid of summer
post #4 of 4 Old 01-13-2015, 11:00 AM
lugnut1009's Avatar
Quoted: 8 Post(s)
You ever fix your issues? I was actually searching for an answer to another question when I came up on this thread.
SOLD (AND SORELY MISSED):1996 F250 CC SB ZF5 4WD
9000LB Ramsey winch, 3" dp, straight exhaust, superchips mini max, 6637 filter,
4" Superlift, 315/75 Toyo MT's, custom step bars
2011 F150 CC 2wd with V6 Eco-boost
factory twin turbo and intercooler, 365 hp and 420 ft/lb torque
lugnut1009 is offline
