2000 rpm hesitation - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-09-2014, 06:25 AM Thread Starter
2000 rpm hesitation
Problem - in neutral if you rev truck cold or warm it will stopped around 2000it rpms stumble had it backfire like a car once after a second of this it will the jump to rev limiter.
During the hesitation it smokes bluish white perfusely and immediately clears.when jumps to redline.
Fixes tried - re oring original injectors
electric fuel. Constantly 65 psi
Drain fuel tank and refill with new.
different known good injectors also with their own new orings
tried different idm out of good running truck
checked ipr tin nut, changed ipr solenoid with known good. Cant remember if i tried my spare ipr
Disconnected icp and ran
Checked for burnt pins on injector harnesd
Pickup info - 96 f250. A previous owner had it chiped, 2 reman injectors. Garret intercooler with pipes that go into wheel wells unknown brand. 3'' downpipe open exhaust
What should i try next to get rid of this wretched problem? I have 2 spare stock hpops, spare ipr, i could go get new uvchs have spare vc gaskets unused
Joe
____________________________________________
1996 SCLB 7.3L Auto - ZF5 Swap, E-Fuel, Baldwin air, 10k Mod, Rosewood Stage 1s, 17* HPOP -=-Sold-=-
1996 CC 7.3L Auto - Banks intercooler " 2 grand its home 6-28-13 needs Fpump and redone exhaust manifolds. to be finished soon
1967 Ford Fairlane 390and FE BBlock - 500HP playtoy
2012 F-150, bone stock.
96strokerlb is offline
post #2 of 10 Old 02-09-2014, 06:39 AM
It sounds like your egr valve may be sticking. I had a similar problem , sometimes truck would be sluggish off the line and smoke like crazy and after a few seconds truck would run great. Dealer diagnosed it with bad egr valve, code p040. You could try cleaning yours first, my egr valve had 157k on it. No issues after new egr valve was put in. Good luck.
pperchansky is offline
post #3 of 10 Old 02-09-2014, 07:00 AM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
No egr on an OBS, Sounds like either another injector going out or a high pressure oil issue. Have access to a good scanner?
Trucks and parts............
kanuck15 is offline
post #4 of 10 Old 02-09-2014, 07:14 AM Thread Starter
I can get it scanned. It cant be an injector issue as i swapped a good set of 8 i had on hand in. Im figouring i have it narrowed down to. Oil pressure. Ipr or hpop bad, or uvchs. Just want to see if anyone has more light to shine on the problem then i currently have.
Joe
post #5 of 10 Old 02-09-2014, 07:28 AM
kanuck15's Avatar
Quoted: 10 Post(s)
Out of curiosity how do you know they are good?
kanuck15 is offline
post #6 of 10 Old 02-09-2014, 08:22 AM Thread Starter
I pulled them out if a truck that was in an accident. Ran and drove just fine
Joe
post #7 of 10 Old 02-09-2014, 08:28 AM
kanuck15's Avatar
Quoted: 10 Post(s)
That doesnt mean a whole lot. They may only be good cause the fuel/high pressure oil systems were able to keep up with a bad injector.
All I am saying is dont rule it out. A contribution test will tell you a lot
kanuck15 is offline
post #8 of 10 Old 02-09-2014, 08:44 AM Thread Starter
I can do a buzz test cant do a contribution due to zf5 swap and having auto cpu.
Joe
post #9 of 10 Old 02-09-2014, 10:51 AM
kanuck15's Avatar
Quoted: 10 Post(s)
Ewww yeah that causes an issue. A buzz test will tell you a lot about the UVCHs and wiring
kanuck15 is offline
post #10 of 10 Old 02-12-2014, 08:35 AM Thread Starter
Well after ipr swap and oil change problem appears to be gone for now.
Joe
