fuel pump help - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-08-2014, 07:55 PM Thread Starter
fuel pump help
Alright guys i need some help i was just wondering if you can run a electric pump with the mechanical pump i hope i got this in the right thread
banshee_rider_#25 is offline
post #2 of 11 Old 02-08-2014, 08:37 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Welcome!
What year and model of truck are we talking about? Are you wanting to convert to e-fuel or what is your though behind running an e-pump with a mechanical pump (normally you would not run both)? Cheers!
Patrick Feeley is offline
post #3 of 11 Old 02-08-2014, 08:58 PM Thread Starter
Its a 95 f250 the only reason is i think my mechanical pump is goin out and ive already got the electric pump and i was just curious if u could leave the mechanical pump in it without having to bypass it through a y block
post #4 of 11 Old 02-08-2014, 10:54 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
No you cant because the stock fuel bowl cant handle the higher pressures an e-pump would create you have to do a complete e-fuel conversion or replace your fuel pump.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 11 Old 02-09-2014, 07:41 AM Thread Starter
I dont have a high pressure e-pump the one i got is a low pressure it puts out like 4-7 psi is tht to much or would i just be better off to put a mechanical pump back in it and be done
post #6 of 11 Old 02-09-2014, 08:41 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 368 Post(s)
That's no where near enough pressure. Obs is generally around 30-40 psi. You'll wipe injectors out with that low of pressure.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #7 of 11 Old 02-09-2014, 09:23 AM Thread Starter
So i would just be better off to just stick with the mechanical lift pump right
post #8 of 11 Old 02-09-2014, 10:37 AM
Quoted: 82 Post(s)
Feedback Score: 4 reviews
If you don't have plans for major modifications such as huge injectors a replacement mechanical pump will be just fine. I highly suggest you replace all the soft hoses in the engine valley at the same time.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #9 of 11 Old 02-09-2014, 10:42 AM
The pump it sounds like you have is for maybe a carbed gas vehicle. Your choices are pretty much do a diy efuel i did mine for about 350$ or aftefmarket efuel ...idk price but expensive. Highest price parts for efuel are regulator and pump otherwise other parts are cheap all parts/fittings/hoses can be found on ebay. And writups are throughout the forum
Or replace stock pump for almost same price.as efuel if you have mechanic do it to slightly cheaper if diy.
Benefits of efuel are more consistant fuel flow, less parts in engine bay helping with lesser chances of leaks, better starting, ive noticed better acceleration others have to as pump doesnt have to build pressure.
Joe
____________________________________________
1996 SCLB 7.3L Auto - ZF5 Swap, E-Fuel, Baldwin air, 10k Mod, Rosewood Stage 1s, 17* HPOP -=-Sold-=-
1996 CC 7.3L Auto - Banks intercooler " 2 grand its home 6-28-13 needs Fpump and redone exhaust manifolds. to be finished soon
1967 Ford Fairlane 390and FE BBlock - 500HP playtoy
2012 F-150, bone stock.
96strokerlb is offline
post #10 of 11 Old 02-09-2014, 11:17 AM Thread Starter
I just order the mechanical pump ive already got the new fuel line to replace from the pump to the bowl ive got a mechanic thts gonna do it for 70 bucks i would do it but i aint got the tools and the pump i had was for diesel it was one of them green mr gasket pumps
