cal. pcm - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-07-2014, 07:18 PM Thread Starter
cal. pcm
I need a pcm for 97 F-250 7.3 cali- emissions F7TF-12A650-RC
FOXRIDER76 is offline
post #2 of 2 Old 02-07-2014, 08:29 PM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
Welcome to the forum!
The DPC-312 PCM with the MME series codes (you have an MME2, but you could use any MME code) are very hard to find. You could send yours out to see if it could be repaired, but it's not cheap. You could also use the much more common DPC-202 PCM and have it flashed with a MIF series code (California 1996 split-shot code). This would also require re-pinning the harness' PCM connector, but if you are in a jam, it's another option. Let me know if you need more info on the what the wiring differences are. Cheers!
Patrick Feeley is offline
